1986 trail boss 250 help
Old Nov 30, 2010 | 09:47 AM
frogryder's Avatar
Default 1986 trail boss 250 help
can anyone tell me were the carb vacume line goes to?
Old Nov 30, 2010 | 09:50 AM
frogryder's Avatar
it seem a mouse has gotten ahold of my bike.
bike wont idle or much less start hope its the problem
Old Nov 30, 2010 | 04:44 PM
Bowana's Avatar
Better pull the air box and have a peek inside.
Also, did you use fuel stabilizer when you put it away the last time as varnish may be part of your runability issue.
Old Nov 30, 2010 | 05:55 PM
ftwflh's Avatar
No vacuum line just intake line and vent line.Take carb off and clean it good take the jets out and clean them.Take the belt cover off and blow out the ducts.Mice build nests in there and if plugged will blow a belt in a hurry
Old Nov 30, 2010 | 09:53 PM
randyneff6971's Avatar
I`m sure your referring to the vent and drain lines. there should be 3 of them. the one on the bottom of the carb is an over-flow drain, the other 2 (1 coming from each side of the carb) I`m sure are vents, on my old trail boss they were linked together and need to be passioned somewhere higher than the mud or water will go.
When I first got my old trail boss i had someone redo the carb and he put all the lines pointing down to the underside of the quad and every time in went in mud or water deep enough to hit the floor boards the motor stalled. it took me some time to figure out it was the carb vent line that was causing the problem
This might not be the proper way to run them but I had to research everywhere and figure it out on my own it worked for mine I`m sure it will work on yours.
Old Deer Hunter
Sep 2, 2015 01:39 AM
Anomers
Aug 16, 2015 11:06 AM
Backwoods_badass
Aug 2, 2015 10:40 PM
Backwoods_badass
Aug 1, 2015 10:25 PM
Gnuters
Jul 19, 2015 10:03 AM
