T-wolf moving in gear
Old Dec 2, 2010 | 05:19 PM
team_realtree's Avatar
Default T-wolf moving in gear
When my atv is in neutral it idles nice but when i put it in gear and just let it sit there it will lurch forward every time the engine fires. It doesnt actually move it just kinda rocks forwards and then rolls back that short distance. Then if i go back to neutral the rpms go up. Is that normal? Its like its trying to move in gear so its under load and then when i put it in neutral there is no load so it starts to idle fast. Then when its idling fast if i put it in gear i go lurching forwards. The thing that throws me off is that before i start shifting after its first started up it idles good.
Old Dec 2, 2010 | 09:09 PM
Another weird thing I thought I would add-
When the key is in the on position while running the RPM's are high but if I switch it to the off position while running they drop to a normal level.
Old Dec 4, 2010 | 10:12 PM
Any ideas on either problem?
Old Dec 11, 2010 | 12:09 PM
budd68's Avatar
It sounds like you need to set the clutch free play or your idol is turned up to high.
Old Dec 12, 2010 | 03:24 PM
judas009's Avatar
mine did that too because my idle was really high. it should be on the side of the carb where your throttle is. its just a **** and play with it until its where you want it.
Old Jan 5, 2011 | 01:50 AM
beaverhunter420's Avatar
it definately sounds like a carb tuning problem, id check for air leaks
ghost civic
Jan 15, 2020 07:43 AM
greg74
Sep 10, 2019 03:03 PM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
DeFox500
Technical and How-To Articles
Jul 26, 2015 02:07 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
