installing camshaft
Old Dec 23, 2010 | 08:29 AM
rccub23's Avatar
Default installing camshaft
1996 polaris sportsman 500. getting ready to replace the camshaft and rocker arm assembly. is there anything special i need to know. is it a pretty straight forward repair. thanks. merry christmas.
Old Dec 23, 2010 | 09:48 AM
TLC's Avatar
TLC
This is a quote from Big Boss 800.
http://forums.atvconnection.com/pola...ve-gas-10.html
To remove cam start by remove cam gear cover rh side, 8mm socket. down by pull start there is a 5/8 bolt sticking up remove this to see timing mark pull eng over to tdc. remove cam tentioner ( 2 8mm bolts rh side) . remove 3 bolts that hold cam gear to cam(mark gear to chain) tie gear up with wire keeping tention on chain. go to left side remove water line elbow fron head(2 8mm bolts, remove 3 8mm bolts that hold decompession cover on. and slide cam out left side carefull not to let decompression parts fall out of center of cam.
Then buy a $40 Cylmer manual is my sugestion. http://www.themanualstore.com/Polari...al-p/m3654.htm Did you buy the higher duration H.O cam? It will give you more mid to high top end power.
Only run "Full synthetic 0W-40" in that motor or you will be doing it again.
Is this what your old one looks like?
Old Dec 23, 2010 | 10:43 AM
Kerbbirds's Avatar
might look at doing the HO mod, buy a cam for a 2001 and up 500 ho, get a 40mm carb off one, need the intake boots for engine and air box, it will give you quite a bit more power, they said 20% cam cost the same, should be able to find carb on e-bay, boots arent that much,
Old Dec 23, 2010 | 11:08 AM
TLC's Avatar
TLC
Carb is not necessary though, I person I know put a H.O motor in his Sportsman 400 and kept the 32mm carb. He said it worked out great without even a re jetting . Here is his PM
Hi TLC,
Just wanted to thank you for the info you gave me on the engine swap on the '05 Sportsman 400. The 500 H.O plugged in there with little hassle and ran like a champ......didn't even have to change jetting on the 32mm which I found odd. Anyway, I really appreciate your help!
I would think the cam alone would make a good performance improvement even without the larger 40mm carb.
Not sure but I think Polaris only makes the H.O cam now. The Part number is 3085855
This guys sell it for $223.52 http://www.cyclepartswarehouse.com/f...2006&fveh=5685
Old Dec 23, 2010 | 11:39 AM
Kerbbirds's Avatar
I did this with the500 motor in my 425, tried the 34mm carb first it ran ok but when I went to the 40mm with a 152.5 main it was a big improvement
Old Dec 23, 2010 | 04:55 PM
rccub23's Avatar
my old cam looks just like the pic. i have the cam and rocker arm replaced. wasnt too bad. runs much better, no more backfiring thru the carb. but now i have the problem of it not wanting to run full throttle. when i give it full throttle, it takes a bit for it to get to full throttle. when i put the airbox on, it wont rev up at all. seems to be running rich too. any thoughts. i have ordered a manual, but its not here yet.
Old Dec 23, 2010 | 05:54 PM
TLC's Avatar
TLC
Being that its a 96 I would check for worn buttons in the secondary clutch, that causes a problem like that.
Part #16 in pic ,there only $3.50 each. (3 of them) OEM motorcycle and ATV parts from Honda, Yamaha & Polaris – Cycle Parts Warehouse
Old Dec 23, 2010 | 06:00 PM
Kerbbirds's Avatar
ditto on the buttons if you havent replaced them yet they are probably gone
Old Dec 23, 2010 | 07:14 PM
rccub23's Avatar
i will replace the buttons. thanks again.
ReconBayou
Oct 31, 2022 05:37 PM
2many2ride
Sep 27, 2015 04:35 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
toonces
Sep 5, 2015 01:14 PM
