LONCIN ATV70cc will not start
Old Dec 27, 2010 | 05:47 PM
ATOMIK70CCATV's Avatar
Default LONCIN ATV70cc will not start
Hey guys
I have an ATOMIK 70cc ATV for my kids, was running fine for a while but was gradually getting harder to start and now will not start. So far i have changed spark plug(there is a good spark). I noticed when inspecting plug it appeared dry so i assumed carby problems, cleaned carby still no go, brought new carby still no go.
I decided to check timing after reading some posts in other forums, noticed timing marks don't line up perfectly( about 1/2 a link out) will this prevent it from starting??? also noticed starter motor chain is loose?? or is there something else i should be looking at. Your advice will be appreciated
cheers
Old Dec 29, 2010 | 03:07 AM
Update on problem.
Tried spraying some start ya bastard while starting, engine still not running?? I might have to put it in to find out problem? any ideas b4 i bite the bullet and spend more money ?????
Old Dec 29, 2010 | 12:57 PM
s0eebuch's Avatar
How's the battery? I had a Kawaskai KZ500 that would turn the starter motor for 10 min straight but didn't have enough juice to fire the coil.
Turned out the battery was dying a slow death - enough power to turn the starter but not enough to turn the starter and fire the coil.
I could put it in gear, turn the key on, and "push-start" it and it'd fire up every time.
New battery = immediate start.
Could this be the problem?
Old Dec 29, 2010 | 11:58 PM
LynnEdwards's Avatar
Electrical Expert
Originally Posted by ATOMIK70CCATV
Hey guys
cheers
Don't know this quad.
Is this a four stroke? If so have you adjusted the valves?
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
FWhitt
Jun 13, 2015 02:22 PM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
