Sticky caliper piston?
Old Dec 27, 2010 | 09:39 PM
brainpause's Avatar
Default Sticky caliper piston?
Do I have a sticky caliber piston? My left front wheel had a lot of resistance, so I removed the wheel for inspection. Brake was grabbing, so I adjusted it with the Allen nut. Turned freely, but I hit the brake handle, released, and it went back to grabbing. I can pick it loose with a screwdriver.
If so, do I have to replace the while caliber? Brakes are almost new (done a few years ago, but not a fat lot if use).
Larry
Old Dec 28, 2010 | 07:12 AM
rdeeno's Avatar
Thats what it sounds like to me. If the piston is not stuck and is aluminum, you might be able to rebuild it.
Old Dec 28, 2010 | 05:13 PM
sdm111's Avatar
2 strokes or 4
If I were you I would try taking the pads off pushing the brake to expose a good bit of the pistons then while someone holds the lever down sand them with 400 wet sand paper. Over time the pistons get either rusty or a build up of crud to make them catch. 9 out of 10 times sanding them will make them work just fine.
Old Dec 28, 2010 | 07:12 PM
Overdrive's Avatar
That does work sometimes.
Old Dec 28, 2010 | 09:06 PM
brainpause's Avatar
Thanks! I'll try it!
Old Dec 29, 2010 | 08:07 AM
JCDEYO25's Avatar
I would take the caliper apart and use caliper grease on the guide pins...Moisture will sometimes cause them to seize...Bleed them also...
John
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
