03 Polaris 600 twin 4x4
Old Jan 5, 2011 | 05:28 PM
carterfish's Avatar
Default 03 Polaris 600 twin 4x4
I just picked up a 2003 Polaris 600 twin. 230 hrs 1350 miles, Came with an electric 35 gallon sprayer, and a strap on luggage rack with a seat, for 3300 did I pay too much? Plus I just noticed it is banging into gear taking off, The driveshaft has very little play in it. The noise sounds like its comming from the rear case. What is the popping noise?
Old Jan 5, 2011 | 07:59 PM
Kerbbirds's Avatar
If its popping its probably a cv joint in one of the axles, look for torn boots, jack it up on jack stands and spin tires , youll find it
Old Jan 6, 2011 | 06:59 AM
carterfish's Avatar
Default 2003 sportsman banging rear end
I checked the boots, no cracks. It does not do it after you shift from nuetral, just when there is no strain on the gearbox and you punch it. you heaar aa pop, or clunk before it takes off. How much play should the drive shaft have i've got about an 1/8 in. which doesnt seem like too much.
Old Jan 6, 2011 | 08:09 AM
sammydogs64's Avatar
My 700 twin cluncks as well, I'm told its normal, its kind of annoying expecially when your rock crawling as it clunks back and forth, normal riding I only hear it when I go from Neutral to reveres or revers to neutral
Old Jan 6, 2011 | 09:59 AM
carterfish's Avatar
I think you misunderstood. It does NOT do it when changing gears (N to H ) it does it when power is first applied from a stand still. If you keep pressure on like a slow roll...and apply power there is no clunk, or pop.
Old Jan 6, 2011 | 10:14 AM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
What your talking about sounds normal. My 500 does this as well but it's not real noticeable unless I've shifted gears from reverse to low or high. There is a touch of freeplay in the gears to keep things from binding. But, like mentioned before, jack it up on stands and look for other things like the cv joints to be sure.
Old Jan 6, 2011 | 11:53 AM
carterfish's Avatar
I'm also having another problem already. It will not disengage 4wd. Any help is appreciated.
Old Jan 8, 2011 | 07:32 AM
Kerbbirds's Avatar
plastis roller cage in front diff is broken, you can buy the parts thru john deer much cheaper tha polaris
Roller kit #MIA10666
Cage kit#10667
Seal kit#10654
Old Jan 8, 2011 | 07:53 AM
carterfish's Avatar
Thanks for the help. They guy I bought it from said he will have the thing fixed for me. Its @ the dealership right now. I will let you know if your diagnosis is correct.
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
Jul 7, 2015 11:00 PM
