Ball Joint Replacement?
Old Jan 6, 2011 | 06:40 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
Question Ball Joint Replacement?
2005 SP 500
Any tips/directions for replcing ball joints?
Any aftermarket/American made alternatives to Polaris brand?
Old Jan 6, 2011 | 08:33 PM
switzomatic's Avatar
If you have a grease zerk on the strut unscrew it(eliminates vacuum effect while removing the ball joint), find something of a similar diameter to the bottom of the strut(I save old bearing races or use a stubby socket), place it on the strut bottom and put the castle nut with a thick washer back on the threads. Then you can use a ball joint separator or open end wrench to pry on the nut/washer using the spacer as a fulcrum.
Place the new ball joint in the freezer until you are ready to install and it will go in pretty easy.
New ball joints can be found pretty cheap on ebay.
Old Jan 6, 2011 | 08:37 PM
Overdrive's Avatar
A little heat on the strut helps a lot.
Old Jan 8, 2011 | 07:22 AM
Kerbbirds's Avatar
propane torch around bottom of strut, pair of vice grips on ball joint bolt , hit vice grips with hammer, have new one ready , get a deep socket the same size as bottom of ball joint, install while strut is still hot
Old Jan 10, 2011 | 11:07 AM
Overdrive's Avatar
There is a right way and wrong and my way. I put the nut back on the ball joint. I put the nut in a vice. I heat the strut and I beat on the strut with a hammer. If you use heat the joint will slip out easy.
Old Jan 10, 2011 | 01:13 PM
weedy's Avatar
Any brands better than others? American made brands?
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Dec 15, 2015 03:59 AM
toonces
Jul 28, 2015 01:58 PM
Peter_
Jul 18, 2015 07:06 AM
musselmark
Jul 17, 2015 02:40 PM
