front axles
Old Jan 22, 2011 | 10:05 PM
dogspower1's Avatar
Default front axles
does anyone know if the front axles are both the same as in i can use a left to replace my right in a 01 sportsman 500
Old Jan 23, 2011 | 05:48 AM
Kerbbirds's Avatar
yes I believe they are, look at parts # on ronnies .com
Old Jan 23, 2011 | 06:48 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
as far as i know there is no right or left so there interchangeable.
Old Jan 23, 2011 | 03:32 PM
IQSLEDNECK's Avatar
they are interchangable. Just make sure it's a front axel :-)
Old Jan 29, 2011 | 10:58 PM
dogspower1's Avatar
Got it all back together i put a axle ,hub,bearing,rotor and capiler in the right front all went back very easy when i went to use the awd the right does not work so i checked the power got it,pulled it back apart to check the coil when i turn the switch on it pull the metal ring right to it what could be the problem ,the axle broke why i had to do this
Old Jan 30, 2011 | 08:09 AM
Kerbbirds's Avatar
how hard is it to pull the armature plate away from coil, should be pretty hard, if its easy its probably bad coil
Old Jan 30, 2011 | 07:39 PM
dogspower1's Avatar
checked it today after church and the armature plate pull right to the coil.it not really what i call hard to pull off maybe takes 1 lbs to pull it off. should it be real hard,anyway cleaned it and put back together and seemed to work then but for how long i don't know
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Jul 28, 2015 01:58 PM
carolinabomb
Jul 26, 2015 08:40 AM
tporath
Jul 11, 2015 12:31 PM
Rider252
Jul 6, 2015 03:37 PM
