'04 Warrior 350 Carb problem
Old Jan 23, 2011 | 12:17 AM
RDub's Avatar
Default '04 Warrior 350 Carb problem
Hello
I'm attempting to install a Dynojet kit in this Warrior, but ran into a snag right off.
After removing the carb top plate, the next step is to remove the needle. Well, the two needle valve plate screws are just not loosening up. If I put any more torque on them, they will strip the phillips fittings out.. Then I'm screwed.. no pun intended.
I've soaked them with Liquidwrench a few times but no go..
So what does one do in a case like this?
Thanks
Old Jan 23, 2011 | 03:00 AM
draarong2004's Avatar
i call it pb blaster.....works far better than liquid wrench.....look for it, found at most automotive stores/hardware stores...i live byt he stuff....let that soak in for a day or so, the liquid wrench will only get so far...sometimes trying to tighten them just a little will help break the stress rather than loosening it......i wouldn't try this till after soaking them in pb blaster though
Old Jan 23, 2011 | 10:11 AM
RDub's Avatar
Ok thanks draarong, I'm headin into town this afternoon so I'll look around for it.
Old Jan 23, 2011 | 11:05 AM
c4455's Avatar
I use a impact driver with screwdriver bit to loosen screws in carb you just dont want to hit to hard and break the carb
njrider64
Jul 4, 2017 01:40 AM
Nelson
Jun 20, 2015 01:59 PM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
