07 Rincon Starter issues
Old Jan 23, 2011 | 12:02 PM
Cummins123's Avatar
Default 07 Rincon Starter issues
Tryed to start my Rincon and when I let off my starter button the starter kept turning until everything went dead. also, turning the key off would not shut the power down. Any help with this?
Old Jan 23, 2011 | 05:51 PM
04honda's Avatar
Go to www.rinconriders.com they all have rincons and is the place to go with rincon questions!
Old Jan 23, 2011 | 08:34 PM
JeffinTD's Avatar
What do you mean shutting the key off won't shut power down? Is that only when it is cranking, in which case I'd suspect the starter relay, or when it isn't cranking or running, in which case I'd look for a short in the wiring or bad key switch...
Old Jan 27, 2011 | 07:23 PM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
sounds like a stuck starter solenoid to me....
Old Jan 28, 2011 | 06:17 AM
Cummins123's Avatar
I ordered a new starter relay. What would cause the part to fail. Thanks for the help.
Old Jan 28, 2011 | 06:38 AM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
Sometimes moisture can get in there and corrode the thin springs and seize it all up- I used to repair tractors and saw it all the time. Hopefully this will solve your issue.
Old Jan 29, 2011 | 05:29 PM
Cummins123's Avatar
Replaced starter relay all is good. Thanks for the help.
Old Jan 29, 2011 | 08:30 PM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
Originally Posted by cummins123
replaced starter relay all is good. Thanks for the help.
Nondem
Feb 22, 2020 12:20 PM
ghost civic
Jan 15, 2020 07:43 AM
ghost civic
Jul 19, 2015 10:13 AM
ghost civic
Jul 15, 2015 10:48 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
