2005 brute force 650 belt issues
Old Feb 4, 2011 | 10:30 AM
moerules's Avatar
Default 2005 brute force 650 belt issues
Hey I have a buddy that has one and is blowing belts. This quad had the original belt with 2000 milesuntil 4 weeks ago when dealer insalled a new carllise one now it has gone through 2. i installed the second one after dealer gave me another new one. any ideas maybe they gave him wrong belt?? could it be the deal inside the clutch cover not sure what it does but i have never owned a Kawi thanks for any help
Old Feb 7, 2011 | 04:06 AM
Williebee's Avatar
Post 2005 brute force 650 belt issues
Like you i've never owned a Kawasaki my brother's first quad was a 1988 or 89' Bayou 300 2x4 but it had the manual tranny , if you go to youtube and type in a search on replacing the drive belt you'll find a video of someone changing the belt's ; there's one that show's step by step instruction on replacing a belt on a popo he show's how to check the primary and secondary clutch's as well as the belt replacement !
From what he talk's about it being a simple proceedjure and that it's prettymuch the same with other brand's , or you can search for the Kawasaki belt replacement they have video's covering all brand's you just do a search with the quad you're working on ; the guy that does the popo even has a home made puller that make's easy to pull the clutch's.
There could be belt debri that's causing the problem , and even the clutch spring's could need changing to a stiffer spring ; but what the case maybe this should be of some help at least i hope it does !
williebee.......
Old Feb 7, 2011 | 07:09 AM
Kerbbirds's Avatar
check clutch alignment
Old Feb 7, 2011 | 08:20 AM
NSchindler's Avatar
How would you check the clutch alignment? My cousin has 07 650 (granted, it has a 2" lift and 30" silverbacks), and he is blowing belts almost every 3rd ride. The guy he got it from said that it had a clutch kit (it has different color springs inside). It will get up and ride a wheelie even with those 30" tires, so it has good power, but he is blowing belts all the time. He even bought the $125 Extreme Duty Belt and it is still blowing it.
Old Feb 14, 2011 | 02:35 PM
moerules's Avatar
Not sure but think the stealership was selling me the wrong belt. It was an aftermarket model and when it went both times it ripped the top off the belt in a few spots just so happens it was the area with the # on it. I put a Kawasaki belt on and has been good to go so far!!!
COFatboy
May 2, 2020 12:06 AM
velcro7279
Aug 24, 2015 01:15 PM
toonces
Jul 31, 2015 09:27 AM
Mikesohio
Jul 26, 2015 10:51 AM
tporath
Jul 11, 2015 12:31 PM
