Changing Transsmisson Fluid????
Old Feb 8, 2011 | 08:22 PM
Kyle18ander's Avatar
Default Changing Transsmisson Fluid????
I think ive got water in the tranny and i can find and plug or anything so i can check anyone know where it is ???
Old Feb 8, 2011 | 08:27 PM
Jmuddin284's Avatar
mine has a dipstick... but that's mine...
Old Feb 8, 2011 | 08:31 PM
Kerbbirds's Avatar
what kinda machine?, should be on the bottom of tranny, maybe a skid plate that has to be removed
Old Feb 8, 2011 | 08:32 PM
HawkeyeRider's Avatar
You'll have better luck getting an answer if you post what quad you have.
Old Feb 8, 2011 | 09:02 PM
Sry Its a 2008 sportsman 500
Old Feb 8, 2011 | 09:41 PM
Jmuddin284's Avatar
the diagram that I found shows a hex plug on both sides of the transmission. I don't know if this will help or not, but here's the link if you want to check it out
2008 Polaris SPORTSMAN 500 HO EFI - A08MN50AF/AN/AQ/AR/AS/AT/ Parts, 2008 Polaris SPORTSMAN 500 HO EFI - A08MN50AF/AN/AQ/AR/AS/AT/ OEM Parts - BikeBandit.com
it'll be the two number 14's on there
Old Feb 8, 2011 | 10:49 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
There is no dipstick on your 500 trans/rear end. Left side (Same side as your oil cap and filter) fill plug and right side is a drain plug. Takes approx. 1qt. or to the bottom of fill hole. Should be about half way back on the trans/rear end. If you suspect water intrusion CHANGE IT!!! A quart of fluid is much cheaper than costly repairs down the road in the event that there is in fact water in there.
bigbear350quad
Sep 11, 2015 12:40 PM
Jason Campbell
Sep 7, 2015 02:25 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
Elkaholic
Sep 6, 2015 02:44 PM
