Jetting on Warrior 99
Old Mar 9, 2001 | 05:40 PM
Faraday's Avatar
Any suggestions for jetting a Warrior for speed.
Old Mar 9, 2001 | 06:12 PM
hot_shoe_cv's Avatar
I'm not quite sure what you mean by "jetting for speed"? if you are jetted for the correct fuel/ air mix then your speed is optimal for the current state of your engine. Any inprovement in speed must come from modifications. If you have a doubt as to whether you need to re-jet, only a test ride & plug read, combined with a performance check at various throttle openings can tell you that.
Old Mar 9, 2001 | 06:25 PM
Faraday's Avatar
I am looking for a little more zip to my zap. Take the sluggish out of the throttle.
Old Mar 9, 2001 | 06:37 PM
are you by any chance a doctor? They also are masters of vagueness."Sluggishness in the throttle"...Is your throttle opening the slide fully? Is ther a lot of slop in the throttle before it opens? If so your carb slide will not rise fully inhibiting the flow of fuel..result? less top end
Old Mar 12, 2001 | 08:31 AM
Faraday's Avatar
Electrical Engineer. And I will check the cable. You may be right
ReconBayou
Oct 31, 2022 05:37 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
