4WD wiring problems
Old Feb 21, 2011 | 06:52 PM
Polaris500Sportsman's Avatar
Default 4WD wiring problems
I have a 2006 Sportsman 500 EFI, i went to plow today and noticed the 4WD symbol was not showing up on speedo, switch was in AWD looked underneath at the differential and the wires going into the diff hade been tangled up in front axle and had cut themselves off at the diff. Any suggestions on what to do or has anyone had this happen before
Old Feb 21, 2011 | 07:17 PM
Kerbbirds's Avatar
Gonna have to splice them back together, if they pulled out of diff you have to take diff apart and find where it started,
Old Feb 21, 2011 | 08:22 PM
the 2 wires are still poking out of the diff, the one is about 1" sticking out and the other is just poking out, has anyone had to replace these wires? or spliced them back to together?
Old Feb 21, 2011 | 10:23 PM
need help ASAP as plowing is going to need to get done LOL
Old Feb 22, 2011 | 05:30 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if you cant spice them together the way they are from not enough wire showing then you must take it apart to either replace the wire form source or get enough wire to spice into. imo
Old Feb 22, 2011 | 06:01 AM
Kerbbirds's Avatar
should be different colors on the wires, I would probably solder them thenthen tape and heat shrink, tie them up well so it doesnt happen again
Ragtop
Jun 27, 2015 03:04 AM
FWhitt
Jun 13, 2015 02:22 PM
wildbill59
Jun 9, 2015 02:28 AM
elpayaso
Jun 3, 2015 10:39 AM
elpayaso
May 30, 2015 05:43 PM
