Sprtsman front spring spacers. (sticky) ...what r they for?
Old Feb 22, 2011 | 01:45 PM
SOLOLUCKY's Avatar
Default Sprtsman front spring spacers. (sticky) ...what r they for?
So I was reading the sticky about the front spring spacers...what is the prupose? a lift kit basically? If so why would ya want to jack up the front end and not the rear.
I am prolly off base with that assumption please enlighten me.
Old Feb 22, 2011 | 03:28 PM
reno82's Avatar
The front springs tend to sag so your wheels look like this / \ spacers bring it level | |. I choose to go with HD springs since I added a winch and carry extra stuff on the rack.
Old Feb 22, 2011 | 04:32 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
as reno mentioned that all sportsmans w/ these weak springs start to sag over time and even faster when you put more weight on the front end say like a brush guard and winch and if you fill the storage up front or carry things on the racks they tend to loose there stiffness. so being cheap i desided to make spacers out of cpvc pipe and cuplings to add an extra 1 1/2" to take up some of the slack. it worked good for me and thought i would share it.
Old Feb 22, 2011 | 05:37 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
I've thought about a set like the ones these guys make for adjustable suspension up front. http://www.t-m-2.com/
Old Feb 22, 2011 | 10:09 PM
zeebs's Avatar
Polaris make a version of these as well only a little better to adjust by using only one spanner wrench compared to the 2 it takes with the TM-2's. I installed polaris' on my 800 which is nice because when you dont need the extra clearance you can adjust them down to stock and back up depending on you load. I gained 1 3/4" front ground clearance when they are adjusted up. It might not sound like much but makes a world of difference when you need/want it
Old Feb 23, 2011 | 10:46 AM
TLC's Avatar
TLC
Spacers are a cheaper faster fix for people who do not what to put on HD Springs.
If you really what them stiff use the spacers as well as the HD springs. I put HDs on the front and back.
Old Feb 23, 2011 | 02:08 PM
user493's Avatar
Moto Psycho
tm2 makes spacers for $20 in case you don't want to spend $80 on the pregressors. tm2
Old Feb 25, 2011 | 02:00 PM
Bing43's Avatar
I did this mod on my 2000 sportsman 500 and worked great and cheap.Has held up all last year getting pounded hard thru trails, snow plowing all this winter. Thanks stendori!!!
ghost civic
Jan 15, 2020 07:43 AM
Wnthunting
Jul 9, 2015 03:02 PM
Jkfx400P
Jul 6, 2015 10:04 AM
Mphillips
Jul 2, 2015 07:20 PM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
