Can starter on SP 500 HO be safely removed without removing clutch assy
Old Feb 27, 2011 | 09:54 PM
khentige's Avatar
Default Can starter on SP 500 HO be safely removed without removing clutch assy
Can the starter be removed from a 2005 SP 500 HO without removing the clutch assembly?
I've found that some say yes, and others say no.
please give details if possible.
Thanks
Old Feb 28, 2011 | 06:10 AM
Kerbbirds's Avatar
yes, its on the other side of motor, remove airbox to give you more room
Old Feb 28, 2011 | 02:16 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
Yes, it's tight but can be done. Remove battery connections from starter and loosen the two bolts holding the starter in place. The top bolt will just slide out, then you'll have to rotate the starter motor 180 degrees so the bottom bolt is now on top to remove it. It can be a pain but it's better than tearing off the clutch assembly. IMO
Old Feb 28, 2011 | 04:18 PM
Steeves's Avatar
I don't know how you can rotate the starter with the second bolt still in. I have removed the starter before as stated above, However you must loosen the second bolt completely and then remove or rotate the starter with the bolt not completely out. Like they say above it can be done and gets easier with practise. When I put my starter back on I used some good RV Silcon around the Oring and then slid it in place. I have had no more water infultration to my recoil housing since.
good luck
Old Feb 28, 2011 | 04:20 PM
Steeves's Avatar
Sorry Readymixer 169 you did say to loosen both bolts and then rotate. Read it to quick.
Old Feb 28, 2011 | 04:45 PM
khentige's Avatar
checked with the dealer today and they want $300 for the polaris starter and 2 hrs @ $75 per/hour to do the job for me.
I see two replacement starters online for around $100 and another for $38 both from DBelectric. The more expensive one is a gold starter and the less expensive looks more like whats in the atv now, just metal.
other than the price and color is there a difference? and which do i need for a 06 sportsmen 500 HO?
Thanks
Eric in CT
Old Feb 28, 2011 | 06:44 PM
HaydenS's Avatar
Do the work yourself. It's a great way to learn more about what you bought and drive and also helps make you keep up on the maintanance more often.
Old Feb 28, 2011 | 06:46 PM
Kerbbirds's Avatar
either one will work I would call db electric and ask them I bet the more expensive one is heavy duty, they are good to work with , thats where I get starters and stuff
Old Feb 28, 2011 | 07:39 PM
LOL! Stop drinking before you get online! Just because I do it doesn't mean you should as well.
Old Mar 1, 2011 | 05:04 PM
Steeves's Avatar
readymix 169 you hit the nail right on the head.
