Mojave airbox mods?
Old Mar 10, 2001 | 01:50 AM
99mojave's Avatar
is there anyway to make the air box breath better any help will help thanks..... Jim.
Old Mar 10, 2001 | 11:18 AM
mojavemaniac5318's Avatar
As long as you are not going in any water, you can drill a bunch of holes in the cover to let the air staight into the filter instead of coming through all the tubes from in front of the handle bars.
Old Mar 10, 2001 | 12:59 PM
JD250R's Avatar
If you don't go through alot of water, take off the airbox and get either a K&N or UNI pod filter and mount it directly to the carb.
Old Mar 12, 2001 | 09:54 AM
mojaveaddict's Avatar
Do like jd250r suggest. Put a K&N clamp on filter directly on the carb and if you like to ride in mud and water that is no more than about a foot deep get one of the new "water repelant" outerwear prefilters. This setup seems to work well for me on the two mojaves i run. The stock air box is much lower and in a vulnerable location to cut holes in it. If you do this, be very carefull around mud and water. The location of a clamp on filter is almost as high as the stock intake snorkle which is under the headlight. One more thing, get the 3 1/2 x 4 k&n that has a angle to it, it will help clear the seat/fender assy.
Customer Service #1
May 15, 2020 08:46 AM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
mbriggs
Sep 13, 2015 10:47 AM
1ArmBandit
Sep 8, 2015 08:59 PM
