Need advice
Old Mar 5, 2011 | 11:36 AM
RobertoZammir's Avatar
Question Need advice
I just got a Chineese ATV for my son.He wants to go in a place that has to cross a small river.I ned to know if its secure to pass with this type of unit. I have not make any changes to it.
Thank for your advice.
Old Mar 6, 2011 | 02:50 AM
stano's Avatar
timing a 225 moto 4
Old Mar 21, 2011 | 07:19 PM
ATV Connection Reporter's Avatar
Hello RobertoZammir, the editors have chosen your question!
Originally Posted by ATV Connection
While you didn’t specify which machine you’ve purchased, there are some general tips to consider when taking any ATV into water. Here are some of the critical areas to target:
Carburetor/ Air Box
Make sure the air box lid is in place and secured and that the drain valve is working correctly. Insure that the intake hoses are free from cracks, and the clamps are not over tightened. For the best water protection, position the air inlet pipe as high as possible.
Make sure your air filter element is properly in place and well lubed.
If you plan to conquer extremely deep water, consider running a snorkel kit, which extends the air intake pipe much higher than stock.
Wheel and Axle Bearings
Yes ATVs come with seals on these critical areas but they are designed to keep dust and mud out, not water. Your best defense against water entry to is make sure your bearings are thoroughly packed with quality grease. Leave no spaces for water to enter/ collect.
Read the full response and learn about other considerations by clicking here!
Thanks for asking your question!
Old Mar 23, 2011 | 06:27 PM
Default need advice
Thank you very much for your response.It is very usefull for the rookies in this matters.I will follow those advices .Keep in touch.
ultangler
Nov 30, 2024 01:35 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
kodiacrunner
Oct 4, 2015 11:52 AM
wrencher82
Sep 28, 2015 10:02 PM
