02 Sportsman 500 fuel problem
Old Mar 12, 2011 | 09:38 AM
Green Mtn Sportsman's Avatar
Default 02 Sportsman 500 fuel problem
Hi everyone, I have a 02 sportsman 500 and it seems like it dosen't get enough gas to make it go. it started to happen this fall and keep getting worst. Today I checked the fuel lines to the carb and it seems to be getting plenty from both lines. it will idle but when I give it gas it stalls. If I spray a little fuel into the carb ( I took my air box off to do this )it will rev up fin. I think it might be the diapham or something like that. any help on this would be great. Thanks
Old Mar 12, 2011 | 10:35 AM
dondeere's Avatar
I would drain the fuel tank and clean the carburetor. Make sure the jets are clear. I have been tricked a few times with bad gasoline. High test has better shelf life.
Old Mar 12, 2011 | 03:34 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
welcome to the forum. by any chance has the carb been cleaned? did the bike sit for long periods w/ old gas that is turned bad? if it seems to run better w/ the choke pulled then it indeed is running lean from lack of gas. may be blockage in the carb it self. maybe fuel filter(if there is one) is partly plugged. a couple of ideas.
Old Mar 12, 2011 | 03:43 PM
switzomatic's Avatar
Ditto on the other posts. After cleaning and replacing anything needed run some seafoam in the tank every so often. Stuff works wonders. Also, how long does it sit and what grade gas do you use? Highly recommend using the higher grade non-oxygenated fuel and I always use fuel stabilizer in the gas for my atv's and lawn equipment. The distributors are putting less additives in the gas to save $ so it doesn't stay fresh as long.
Old Mar 12, 2011 | 06:41 PM
3_Polaris_ATVs's Avatar
X2 on The Seafoam. Good stuff. Probably wont clean a plugged jet but will help to keep it clear. If you do clean the carb your self make sure to remove the jets to clean.
Old Mar 12, 2011 | 08:07 PM
Kerbbirds's Avatar
sounds like pilot jet is plugged , ditto on a thorough carb cleaning and seafoam after you clean it,
Old Mar 19, 2011 | 07:38 AM
Well I drained the fuel and put new gas in and after a minute of running it took right off and no longer bogs down any more. I will be puting some sea foam in it to help it out but I can't beleave that the fuel went bad after 3 months. Thanks for all the help. this fourm ROCKS.
skittero
35
Mar 1, 2019 12:39 AM
green giant
Jul 13, 2017 12:07 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
