1998 sportsman 500
Old Mar 19, 2011 | 01:27 PM
N1tr0's Avatar
Default 1998 sportsman 500
need to know how to get the front disk brake pads of the caliper
does the 2 round things screw out of the caliper or how do i get the pads on and off my old ones are wore out
Old Mar 19, 2011 | 04:30 PM
Remove the two 1/2' bolts that secure the caliper to the strut. Remove the 3/16" allen screw in the caliper body (allows more room for bracket to push back further during pad install) use a screwdriver or anything that allows the caliper piston to be pushed in, remove old pads. Best to pull caliper bracket out of body and grease the shafts so the bracket slides easily. Install bracket back on body,install bottom of pad first in bracket,then you can push a little further on upper bracket (where the allen screw goes) to get the top pad in. You still may have to tap the pad to get it over the bracket. After pads are installed, pump up brakes,replace allen screw and tighten until rotor begins to be hard to turn,then back off allen screw 1/4 to 1/2 turn and rotor is free to turn(this aligns caliper to rotor). If this sounds complicated,just get a manual,it explains better than I can,plus is usually illustrated! OPT
Jmuddin284
Jan 19, 2026 07:16 AM
79hugger
Aug 30, 2015 02:21 PM
clsharky
Jul 13, 2015 02:07 PM
honda71
Jul 12, 2015 05:56 AM
honda71
Jul 8, 2015 02:13 AM
