how to remove impeller
Old Mar 20, 2011 | 03:01 PM
bigmo4126's Avatar
Default how to remove impeller
can anyone tell me how to remove my impeller on my ds650, im changing out my clutch, and i cant get theclutch cover off because the impeller is keeping me from removing it.
Old Mar 20, 2011 | 03:55 PM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
Impeller should slide out with the clutch cover. Some folks overlook the two bolts holding the starter on, which will prevent the cover from coming off. Should have 12 or 13 bolts to remove then the two for the starter.
Once all of those are out of the way gently apply pressure to the clutch actuator. A lot of times this will raise the cover off of the center case. Do not force it, jimmy it back and forth and you will see it break loose.
Old Mar 21, 2011 | 06:34 AM
BasicBajaX's Avatar
Keeps busy in the garage building one thing or another.
Yes as Aceisback said...Also take your time putting it back on. Dont force it during install either...
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Canamaniac!
Sep 15, 2015 06:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
