Winch qestion
Old Mar 21, 2011 | 12:01 PM
bully50's Avatar
Default Winch qestion
My old polaris winch on my 1999 sportsman seems to have a mind of it's own, some times it works and others it dosn't so i poped my cover on the machine to check the solenoid, it was so hot to the touch, you could fry a steak on it, is that right? or is this thing stuck open some times and stuck closed others?? i did have a regalotor problem last year, thinking might have somthing to do with that, no idea.
Old Mar 21, 2011 | 02:02 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
If it comes and goes as you say I'd just about bet the farm that the contactor is going bad. Been there, done that. Getting warm would be acceptable but not so hot that it would burn you. Something definitely wrong there. I doubt your regulator would affect it but you never know. Have you tested the voltage output of your regulator? Should be letting no more than 14.5-15volts max through.
Old Mar 21, 2011 | 02:07 PM
bully50's Avatar
Regulator was replaced last year, i'll check the conections, i just thought it was odd the solenoid would be burning hot, even when the winch is not in use. ty for the info.
Old Mar 21, 2011 | 05:55 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
the solenoid should not be getting hot unless something is wrong. is it the old style they used on the a2000 warn winches that has to places to bolt on the frame on each side? if so, the earlier ones they had were known for starting fires and then replaced them w/ an updated one that had black plastic protectors that slid onthe bracks that bolted on the frame.
Old Mar 21, 2011 | 06:15 PM
Kerbbirds's Avatar
yeah Sten remembers too, Warn would send youn a new contactor when the fire recall was going on, might contact them and see
Old Mar 22, 2011 | 07:05 AM
bully50's Avatar
I belive it is the old stlye, so you guys would say replacment? i think they are like 30 or 40 bucks for a new solenoid. or would somthing elsa be making the solenoid crazy hot? thank you guys for the help, this is why i tell every one i know, if they have a ATV this is the place to come.
Old Mar 22, 2011 | 01:57 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i would replace it w/ out question! as long as the wires/cables are all hooked up corrctly and there is no bare wires grounding out or crossed then it should heat up. the only way there shoud be any heat is when you are pushing a winch to it's max and maybe have too light(meaning not enough thick gauge wire) cables causing it too heat up.
Old Mar 22, 2011 | 02:02 PM
bully50's Avatar
Well you saved me once again, I looked at solenoid and turns out it is the one they recalled, so i called warn and without out any hassle they are sending me a replacement. thanks guys!
Johnny Mac
Aug 15, 2019 03:13 PM
salixair
Nov 3, 2015 08:25 AM
cboler9
Sep 24, 2015 08:35 PM
ylomnstr
Sep 10, 2015 06:45 AM
chewy78
Sep 8, 2015 10:37 AM
