Kill Switch for 2011 Sportsman 850 XP EPS
There's usually a kill switch on the left handle area. It's probably a slide that will shot off the quad if pushed either to the left or right. Center is the on position. Just going from memory here as I doubt Polaris has got rid of it.
I think he is just after a tethered switch, like myself. If that is the case, this is the best one i have found, and it has amazing reviews.
Pro Armor Pro Series ATV Tether Kill Switch | Rocky Mountain ATV/MC
@cyberhedz.. that is correct.. looking for a tethered switch.. I'm trying to rigged up to run cross country, but have had trouble finding a switch that will work with the EFI set up. I will take a look at you link. Thanks
dont worry about having one for your bike specifically, the Pro armor is the ****, specifying a vehicle just means that they have a custom harness for it, you can still cut and splice the kill switch in. Plenty of guys on here can help with how to wire it in, its only two wires. I'm planning on installing the Pro armor on my 850 here in a few weeks.
Thanks for the info.. by the way are you having any trouble with oil in your air box... was reading about in a thread.. went and check out mine and sure enough i have the same issue.. guess im heading to the dealer for a fix..
KimSJoh
14
Jul 18, 2015 07:20 PM
TLC
Jul 11, 2015 02:28 AM
ranvette
Jul 4, 2015 06:13 PM
