2001 sporstman 90 no spark
old stator tested out bad according to multimeter, replaced the stator, cleaned flywheel, new battery, tested coil, tried a couple spark plugs, tested kill switch, key switch, tether switch, tried throttle safety switch disconnected, still no spark with electric start or kick.
Was told that somebody jumped it with a car battery jumper to start it a couple years ago, fired up and quit hasnt ran since.
Thinking possibly the cdi is bad, but hate to spend the $ if im wrong.
Wondering also if one should be able to light a test light on the ignition power wire from the stator to the cdi (blk/red) wire, because this one wont, although my multimeter shows it is producing some power.
the red and the white wires out of the stator for the charging system will light a test light
trigger coil is producing a signal for the cdi
