2007 400 Arctic Cat misses when in gear..
Old Apr 7, 2011 | 11:24 AM
bigbitone's Avatar
Default 2007 400 Arctic Cat misses when in gear..
Now let me see if I can explain the problem. I have a 07' 400 4x4 automatic. It misses like it has a rev limiter when it is in gear and accelerating at any speed. But it will run great when I rev the engine while it is in neutral. I have checked all the command things like filters, spark plug, carb, trash or water in fuel, ect.. I even swapped the CDI from another 07' that I bought at the same time and are the same models. Still did not correct the problem. I have been told that if the drive belt is slipping it will cause the rev limiter to engage. Any ideals on it would be helpful.
Old Apr 7, 2011 | 07:34 PM
Kerbbirds's Avatar
how much slack is in throttle cable? there is an adjustment about at thumb throttle, should only be 1/8 inch of slack in cable
95wolv
Sep 27, 2024 12:00 PM
Customer Service #1
May 15, 2020 08:46 AM
tysonbully
Sep 28, 2015 02:30 AM
Sep 23, 2015 06:23 AM
braap123
Sep 7, 2015 12:58 PM
