CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
ds650 skips after it warms up
Old Apr 12, 2011 | 08:18 AM
cirtman75's Avatar
Default ds650 skips after it warms up
my 2000 ds has a total rebuild piston rings clutch stator pickup coils gone through carb 100 times stock carb loony tuned twin pipes it ran great for 6 months the all of a sudden it started to skip above half throttle i was told my ron woods cdi was breaking down i put the stock 1 back on same problem it runs great cold after about 5 min it start to skip after half throttle if i creep the throttle it revs out if i punch it it skips like its electrical which is all brand new thought intake boot was suckn air replaced it no change would a bad coolant sensor make it skip it runs like brand new at idle up to half throttle even when hot aferthat it skip ive sunk thousands it right now i just feel like pouring gas on it and light it on fire i rid in upstate new york
Old Apr 14, 2011 | 09:30 AM
pipelayer's Avatar
I'm a Plumbing contractor and I have some old friends that always called me Pipelayer for some reason?
Where did you get the piston from and what compression is it and what gas do you have in it? I would guess its pre-igniting not for sure but its a big problem with the Ebay pistons saying they are 11to1 and are more like 13to1 because they give you a thin gasket. if its not that I would say jet down a little on top end.
Brian
MeadowlarkFarm
Nov 27, 2019 08:40 PM
IMLN
Sep 28, 2015 03:32 PM
Minimod
Sep 10, 2015 08:03 AM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
black_thunder
Sep 6, 2015 04:41 PM
