Front differential
Old Apr 21, 2011 | 05:51 PM
aircore's Avatar
Default Front differential
Does the front differential with the u joint drive shaft just slide out of engine on a 2005 arctic cat 500 tbx 4+4
Old Apr 24, 2011 | 12:04 AM
swampyjunior's Avatar
I do not believe it does. The secondary drive shaft (as my book calls it) connects to a yoke that bolts to the end of the shaft coming out of the engine. There is a u-joint at the yoke.
I just replaced my u-joint ans front differential seals. To get the u-joint out I removed 3 of the 6 bolts that connect the shaft to the differential then I removes the 2-retaining clips on the caps of the u-joint. I used a small c-clamp to push out the u-joint caps. When it is free from the yoke you can tilt it down and to the side and remove it from the machine. I then placed it in my vice to get the other 2 caps out of the other half of the yoke. You can reinstall in reverse order.
I forgot to mention that the shaft is actually two parts now. they connect in a splined section under a small rubber boot. Clean and re-grease before you reinstall.
Sorry but I did not take any pictures of the process. I think the whole process took me about 1 hour.
Hope this helps.
Swampy
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 6, 2015 10:46 AM
toonces
Aug 5, 2015 05:55 PM
carolinabomb
Jul 26, 2015 08:40 AM
tporath
Jul 11, 2015 12:31 PM
