400 xplorer oil in recoil ???
Old Apr 22, 2011 | 06:37 PM
tahoe700302's Avatar
Default 400 xplorer oil in recoil ???
I have a 2000 400 xplorer and there is oil coming up with my pull start rope. Any ideas?
Old Apr 22, 2011 | 08:53 PM
bigcam400's Avatar
1st id check oil tank level!!,..then pull pug outta bottom of motor an let it drain,...2 strokes dont hold oil but can build up from gas mix some how...
Old Apr 23, 2011 | 01:01 AM
mrtwostroke's Avatar
the recoil area is sealed off from the Counterbalance area not the the crank case.
I guess oil could leak from there into the recoil. Sure it is not water.
Old Apr 23, 2011 | 09:52 AM
Nugget Shooter's Avatar
I had the same issue a while back, black oily feeling pull rope. Turned out to be water in the recoil housing and trashed my starter bendix....
As mentioned pull drain plug and see what comes out.
Old Apr 23, 2011 | 07:39 PM
Drained it and that fixed it. Thanks.
Now, a new problem.
Quit running, would hit once and die. Changed plug, removed carb, getting fuel, removed bowl, checked floats and was getting fuel to the bowl through the float valve. checked low oil meter and it is working as not to kill the fire. The spark plug is getting good fire. ??????
It will hit one good time and die. Wait a few and it will do this again.
HELP !!!! LOL
Old Apr 23, 2011 | 07:59 PM
bigcam400's Avatar
Now, a new problem.
HELP !!!! LOL
idk,...oldpolaristec or somebody will have you some ideas!! good luck!
Old Apr 24, 2011 | 12:26 AM
Now, a new problem.
HELP !!!! LOL
If has good spark,hold throttle WIDE OPEN while cranking,could be just engine flooded,if so may take a couple times doing this. If doesn't help could have compression problem, or leaking crank seal,clutch side usually the culprit on seals??? OPT
MeadowlarkFarm
Nov 27, 2019 08:40 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
rockinkgin
Sep 25, 2015 01:52 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
Jason Richards
Sep 4, 2015 06:17 PM
