electrical problem
Old May 1, 2011 | 08:46 PM
kendem's Avatar
Default electrical problem
my 2006 800 started to kill the battery when it is running. the voltage drops drastically. the battery symbol flashes and the speedo needle flashes untill the quad backfires and dies. with the key off the voltage iss 11.9 volts but it will not start. i have replaced the battery and everything is a ok for a day or so and the problrm starts again. anybody else with the same problem or a fix?
Old May 1, 2011 | 09:12 PM
Check wiring at voltage regulator at front of machine for loose wires,if has good connections then check battery voltage as machine is running. Should be around 14 volts. If showing under(12 volts are less) or overs(say about 16 volts could be shorted out eating up batteries) Either case usually voltage regulator problem,probably needs replacement. OPT
skinnyr6
Aug 25, 2023 02:18 AM
TheHood
Jul 26, 2015 09:51 AM
Chuck188
Jul 17, 2015 02:45 PM
Unzzy66
Jul 11, 2015 10:01 PM
ranvette
Jul 4, 2015 06:13 PM
