Mudlite pressure?
Old May 3, 2011 | 07:57 AM
SOLOLUCKY's Avatar
Question Mudlite pressure?
I just got a set of 26" mudlites on my 500HO...what should the pressure be ?
on the factory tires i have had for years i'd do 5 psi front, 3-4 in rear...never got stuck, but these, at thoase pressures, seem VERY soft in the sidewalls.
What do others run in these treads?
Old May 3, 2011 | 11:49 AM
I generally run about 6 lbs. front and back on my X2. If you can, try different pressures in your tires and ride your terrain and see what works best.
Old May 3, 2011 | 12:11 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
anywhere from 3 to 7 psi depending on what surface you ride on. softer areas where more traction is needed a less psi is ok. hard pack a higher psi for better fuel milage is good. if a low psi is used for rock or hard going traction riding then a lower speed so you don't roll or dismount the tire form hard contact. imo
Old May 3, 2011 | 01:13 PM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
mud lite rubber is on the hard side, but the psi all matters on what kind of terrain you ride on...
you should be on the lower end of 3-5 psi when riding over rocks and such- high psi will tend to make a rubber tire tear wide open if it's impaled... you want that tire to flex.
I ran my ML aroud 4-5psi
Old May 4, 2011 | 07:31 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
I run my ITPs at 5 to 7 psi.
bmxatv10
Oct 14, 2022 06:23 PM
Alex G.
Sep 11, 2017 11:38 PM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
2many2ride
Sep 27, 2015 04:35 AM
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
