Clanking in rear of 2004 trail boss 330
Old May 10, 2011 | 08:25 PM
jd993's Avatar
Default Clanking in rear of 2004 trail boss 330
Everytime i pull out it bangs in the back or or on the side not sure where and it only happens when going slow or pulling out. When you gain speed it doesnt do it any ideas what it can be. Thanks
Old May 10, 2011 | 09:14 PM
Could be wheel hub slack,rear carrier bearings worn/loose,kinked chain link,too much chain slack?
Jack up rear end,check play on drive shaft see if its loose. OPT
Old May 10, 2011 | 09:19 PM
jd993's Avatar
thanks ill check it out
Old May 10, 2011 | 09:31 PM
jd993's Avatar
hey do you think it can be something in the tranny also just in case they dont work thanks alot for the help
Old May 11, 2011 | 06:26 AM
tonythom's Avatar
Not sure hat you mean by clunking but I have had several trail boss machines and everyone of them eventually needed a silent chain. It is a chain in the transmission that gets loose. Sounds like a sprocket jumping a couple teeth when you take off sometimes. TonyT
Old May 11, 2011 | 07:59 AM
Raven95150's Avatar
Check your belt too. If your belt has a burned spot, it will make a clunking sound at low speeds.
Old May 11, 2011 | 11:52 AM
jd993's Avatar
thanks ill check them out
Gnuters
Jul 19, 2015 10:03 AM
WilliamBos
Jul 13, 2015 02:11 PM
rcappie4
Jul 10, 2015 04:54 PM
Rider252
Jul 6, 2015 03:37 PM
