04 Arctic Cat 650 has no electric
Old May 16, 2011 | 05:40 PM
WillieT's Avatar
Default 04 Arctic Cat 650 has no electric
I have an Arctic Cat 650 that is electrically dead. It started then would not start an hour later. There is no electric activity, no lights, no power to the winch, nothing. I charged the battery and everything came on a few hours later. I started the ATV, then turned off and tried again, everything was dead again. Thought maybe a short in the battery, so I replaced it. Everything came on, I turned the key off and it was dead again and nothing worked. The battery itself reads over 12 volts when metered. The atv has not been moved and all of this has taken place in a stationary position, so not like anything is being jarred loose.
I have tried using the pull cord and it will not start the atv either. Has anyone else ever had this problem? I'm not even sure where to look.
Thanks for any help.
Old May 16, 2011 | 11:25 PM
TexasRoadlawyer's Avatar
No Ruts, No Glory
basics first....are your connections to the terminals good and tight?
Old May 17, 2011 | 05:53 AM
weez440's Avatar
pull off the cdi, there are 3 plugs and usually you can smell if it is burnt out. if it is burnt out i have a cdi i will sell you.
Old May 17, 2011 | 03:03 PM
Fossil's Avatar
"If you haven't any charity in your heart, you have the worst kind of heart trouble." ~Bob Hope
Check and make sure the ground to the ATV is OK. Not sure if it grounds to the engine or frame.
ReconBayou
Oct 31, 2022 05:37 PM
EIF
Apr 20, 2017 07:15 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Sw00p
Sep 24, 2015 02:50 PM
