Water res pissing out the cap
2001 ds650 brand new top end 11.5:1 je cometic top end kit omr carb mods Stock gearing radiator fan not installed
When I'm out riding coolant will shoot out the weephole in the coolant reservoir cap. What causes this? My overheat light never illuminated and the quad runs very strong. No water in oil. No oil in water. Plz help. Thanks.
Does it only **** after riding for a while and it has warmed up, or will it do it cold at high RPM. If its the first then your probably overheating due to lack of fan and your overheat sensor is bad. If the later then you have a leak in your headgasket...
Customer Service #1
May 15, 2020 08:46 AM
jrooker6
Apr 23, 2016 07:36 PM
