Water res pissing out the cap
Old May 27, 2011 | 10:05 PM
chrisc321's Avatar
Default Water res pissing out the cap
2001 ds650 brand new top end 11.5:1 je cometic top end kit omr carb mods Stock gearing radiator fan not installed
When I'm out riding coolant will shoot out the weephole in the coolant reservoir cap. What causes this? My overheat light never illuminated and the quad runs very strong. No water in oil. No oil in water. Plz help. Thanks.
Old May 27, 2011 | 10:47 PM
atvkiller's Avatar
what im wondering if the collent is getting hot enough to boil over i know in a car it can do the same thing and not over heat did it ever do that when th fan was on it
Old May 28, 2011 | 05:33 AM
snow racer's Avatar
Why no fan?!!! It is on there for a reason.
Old May 28, 2011 | 10:05 AM
chrisc321's Avatar
It was missing when I got the bike. I have plans to get the one from ebay within a month.
Old May 28, 2011 | 11:29 PM
infantryvet's Avatar
i would try to run some water wetter or redline instead of just water alone.Its probably boing over.keep an eye out for head gasket leaks,could be pressurizing the system somewhat..
Old May 31, 2011 | 10:34 AM
DSengineer's Avatar
Has been here a long time!
Does it only **** after riding for a while and it has warmed up, or will it do it cold at high RPM. If its the first then your probably overheating due to lack of fan and your overheat sensor is bad. If the later then you have a leak in your headgasket...
Old May 31, 2011 | 10:51 PM
chrisc321's Avatar
It only does it after riding a while. I figured it was just getting too hot. Will get a fan soon. Thanks for the help!
Customer Service #1
May 15, 2020 08:46 AM
Alex G.
Sep 11, 2017 11:38 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
awer1968
Sep 8, 2015 11:02 AM
