My XTR goes right down the drain
Old May 31, 2011 | 10:45 PM
IQSLEDNECK's Avatar
Thumbs down My XTR goes right down the drain
PISSED
Ran over a short pice of 1/2" copper pipe... Cut a hole in my tire and was stuck in it for a while... I hope a patch and tube will fix it rather than a $140 for a new tire
Old Jun 1, 2011 | 01:01 AM
bigcam400's Avatar
dubble plug it,..itll be fine,...if you really worryed bout it pull it off wheel an get a boot put in it,...last thing you wanta do is put a tube in it!! if it go flat on trail you patchin a tube an re-installin on the trail to get home!!
Old Jun 1, 2011 | 04:42 AM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
that's an easy plug-
does suck when you pop a new tire though
Old Jun 1, 2011 | 07:41 AM
I've run as many as 3 plugs in a tire with a hole that size without any problems. Just put them in with a lot of glue. I put another 1000 miles on my original tires like that.
Old Jun 1, 2011 | 08:02 AM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
I saw bgirard420's tire on sunday- had 3 plugs going in and out his sidewall- got pinched on a sharp rock and took a nasty slice out of it, top & bottom- I've never seen a tripple plug going in one hole and exiting another on a sidewall - he says it leaks no air... so far
Old Jun 1, 2011 | 08:57 AM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
That sucks but easy fix, how the hell did you manage to run over a copper pipe? It wasn't laying along a trail was it?
Old Jun 1, 2011 | 02:21 PM
IQSLEDNECK's Avatar
Yeah the tube was about 4-6" long and was sticking right in the tire...it was half in my tire and half out! Worst part is, the tires have less than 200 miles on em
Old Jun 1, 2011 | 02:58 PM
xFreebirdx's Avatar
Administrator¿
Resident Killer!
"A little nonsense now and then, is relished by the wisest men". Willy Wonka: 1971
Cigars! Earth ne'eer did breed such a jovial weed.
A Tiger Doesn't Lose Sleep Over Opinions of Sheep
Veteran: Army
Loved
Community Favorite
The best thing to use for an off road tire is a patch - plug combo. They have them in different sizes and it will be a permanent fix. The tire will have to come off the rim to put it on.
Old Jun 1, 2011 | 03:07 PM
bigcam400's Avatar
yes,..thats them "boot"s i wuz refering too,..works on tubeless big truck tires with up to 120lbs air pressure with 80,000 pound GVW!!
Old Jun 1, 2011 | 04:43 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i have that happen to my xt'r but they were side wall cuts that i used reg plu style plugs and slim and worked preety good but ened up replacing the tire. those plugs you guys are refering too didn't work good on my stock ptx tire i had. had to put a tube in it to stop it leaking.
