My XTR goes right down the drain
PISSED
Ran over a short pice of 1/2" copper pipe... Cut a hole in my tire and was stuck in it for a while... I hope a patch and tube will fix it rather than a $140 for a new tire
dubble plug it,..itll be fine,...if you really worryed bout it pull it off wheel an get a boot put in it,...last thing you wanta do is put a tube in it!! if it go flat on trail you patchin a tube an re-installin on the trail to get home!!
- he says it leaks no air... so far
Yeah the tube was about 4-6" long and was sticking right in the tire...it was half in my tire and half out! Worst part is, the tires have less than 200 miles on em
Administrator¿
Resident Killer!
"A little nonsense now and then, is relished by the wisest men". Willy Wonka: 1971
Cigars! Earth ne'eer did breed such a jovial weed.
A Tiger Doesn't Lose Sleep Over Opinions of Sheep
Resident Killer!
The best thing to use for an off road tire is a patch - plug combo. They have them in different sizes and it will be a permanent fix. The tire will have to come off the rim to put it on.
yes,..thats them "boot"s i wuz refering too,..works on tubeless big truck tires with up to 120lbs air pressure with 80,000 pound GVW!!
i have that happen to my xt'r but they were side wall cuts that i used reg plu style plugs and slim and worked preety good but ened up replacing the tire. those plugs you guys are refering too didn't work good on my stock ptx tire i had. had to put a tube in it to stop it leaking.
