Engine nose
Old Jun 6, 2011 | 05:44 AM
muddzilla's Avatar
Default Engine nose
I have a 2009 sportsman 500HO EFI and i have 20 hrs on it i noticed that the engine makes a lot of noise, like valve tapping noise is this normal?
Old Jun 6, 2011 | 06:01 AM
When Polaris removed the recoil assembly and just used a blank recoil cover,the noise radiates through the cover a lot more than the older models with the plastic reel,rope and other parts. You're hearing a lot more cam chain,flywheel noise plus noise radiating down. This was the first thing I noticed when they came out! (cost cutting!!) Possible to remove cover and try to insulate with automotive stereo noise barrier sheet or I even though of spray foam??? Haven't tried either way, DON'T know if would stay secure and not get into flywheel or stator area! OR you could spring for a complete recoil assembly (over 200 + dollars) and also have the backup recoil in case battery gets low. OPT
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
Jul 30, 2015 09:39 AM
ltrmc02
Jul 22, 2015 04:50 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
