Made the purchase
Old Jun 11, 2011 | 11:48 AM
lawnboy2121's Avatar
Default Made the purchase
Just bought an 2011 xp850 eps le any one with any advice on the machine. So far its seems awesome but time will tell. Only two miles on it can not wait for the break in to be over. Any one know if it will keep up with an outlander 800 once broken in.
Old Jun 11, 2011 | 12:32 PM
OutlawJim's Avatar
Nice buy, no question about it! Those new XPs pull HARD, will definitely keep up with an Outlander. The new engines will actually run better and better as they get worn in. Bought my dad a 550 for his 55th birthday and he's been extremely happy with it
Old Jun 11, 2011 | 12:53 PM
Slight edge to the Outy 800 from what I've seen, speed-wise. More comfortable ride than the Outy though. Great quad. Congratulations.
Old Jun 12, 2011 | 05:31 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
alot of good post on the xp850 on here if you do a search. i would dought it will be faster thenthe outlander. a very nice buy for sure. enjoy it.
Old Jun 12, 2011 | 08:53 AM
thanks any advice on the machine. been awhile sinse i had a new machine . My other was a 05 sp700 big difference.
Old Jun 12, 2011 | 09:56 AM
rmax's Avatar
Default 850xp
one of our riders has a o9 i think , with a small lift running 31 laws, he has had several problems with ball joints, tie rods, an had a gear reduction added, the mechanic that did the gear job showed uc a spacer that he could not find a place for, so he left it out, we took the quad as we had a planned ride that weekend, every time he got on the gas then let off the trans would lock up (forward or reverse)an the belt would get wet in any water at all, fought that crap all weekend, took it back to dealer (same dealer diff mech)they had to replace the entire trans, but said the belt getting wet was from our snorkle job, ended up puttiny water hose in belt intake an filling it until water came out the ex side of the snorkles, found the water leaking from the inner belt houseing , the first mech had used a grinder of some sort to remove the sealant from the mating surface to the engine case an messed it all up, the2nd mech missed seeing this an put it back on useing some cheap sealant, the pressure in the belt houseing blew the sealant out an it leaked agian , got that fixed now its doing well. i guess the point i am trying to make is do not let just any *** hole work on your machine
Old Jun 13, 2011 | 05:18 PM
thanks for the advice i do most of the work on my machines myself dont trust anyone.
Customer Service #1
May 15, 2020 08:46 AM
fordfaithful21
Dec 7, 2015 05:52 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Elkaholic
Sep 6, 2015 02:44 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
