86 250 trail boss won't start
Old Jun 26, 2011 | 10:15 PM
bearl_baker's Avatar
Default 86 250 trail boss won't start
opt i am working on a 86 trail boss 250 just replaced the rings crank seals and cleaned carb got fire at the plug and have fuel but wont run or start cant use electric starter becaus it is fried.
replaced stator with a 91 was toled it would work
Old Jun 27, 2011 | 02:12 AM
You are posting twice,replied to this question on first post,need a little more info on piston and rings and stator connections. OPT
Old Jun 27, 2011 | 04:30 AM
i have 120 psi comp. i used the 86 plugs and color matched the wires to the plug off old stator.
Old Jun 27, 2011 | 04:42 AM
Does it try to start at all? only other thing I can think of is timing? On the old 86 can't remember if you can adjust the plate a little(advance or retard) plus the cdi affects timing(replaces the old points and condenser) also and may not be compatible with the 91 stator as far as timing since the cdi units show to be different part number? OPT
Old Jun 27, 2011 | 09:26 PM
randyneff6971's Avatar
Also to add to this. if it somehow got flooded you will have to drain the crank case before it will start. there is a 10mm bolt on the bottom of the crank case. That is the crank case drain, undo it and take it out there should be nothing come out if there is excessive fuel there it will drain. You might also want to check and see that the exhaust is clear also. if the motor flooded there could be enough gas in the Exhaust preventing the motor to breath.
Old Jul 11, 2011 | 10:02 PM
put in a diferant cdi box out of a 90-92 and it started up
Old Jul 12, 2011 | 04:20 AM
Glad you got the right cdi and it runs! Keep it going,one of the oldest around! OPT
wildbill59
Jun 20, 2015 02:26 PM
PolarisPower500
May 17, 2015 02:28 PM
Rod
Oct 4, 1999 12:37 PM
EXtreme
Sep 10, 1999 12:54 PM
Matt24
Aug 3, 1999 07:46 PM
