325 magnum VS 500 Magnum final drive ratio
Old Jul 7, 2011 | 11:03 PM
Oldsman67330's Avatar
Default 325 magnum VS 500 Magnum final drive ratio
Does anybody know what the final drive (ring and pinion) ratios are for a 2000 325 magnum and a 2002 500 magnum are? I bought a 500 that fell off a trailer and bent all 4 wheels, so I was going to use a set that I had in the barn, only to realize the 500 had 12" wheels and mine were 10", tried changing hubs, old hubs won't fit, ended up swapping out the whole rear axle from a 325 parts machine I have until i can get ahold of some wheels. I'm just curious how much if any difference there is in the final drive ratios.
Old Jul 8, 2011 | 07:40 AM
None if any I would think as both the 325 and 500 have a 31 tooth ring gear and a 10 tooth pinion gear,even though the part numbers are different. OPT
scram5050
Aug 30, 2024 01:39 PM
Cummins Driver
Sep 11, 2019 01:22 PM
toonces
Jul 31, 2015 09:27 AM
kdg723
Jul 25, 2015 01:20 PM
tporath
Jul 11, 2015 12:31 PM
