KFX 80 rebuild
Old Jul 9, 2011 | 03:31 PM
centurion Power's Avatar
Default KFX 80 rebuild
Did a engine rebuild on a kfx 80 due to a cracked case and I have a problem.The engine is put back together and spins freely. The problem is the engine spins freely until I put the spark plug in. Then the battery doesnt have enough power to turn the engine over. The piston is not hitting the spark plug and I have ruled out the battery. Any suggestions?
Old Jul 9, 2011 | 08:12 PM
Problem solved.
Old Jul 9, 2011 | 10:19 PM
LT80's Avatar
LT80 Expert
What was it?
Ground problem?
Old Jul 10, 2011 | 09:22 PM
Your good,
Here is my latest issue. The quad starts right up and idles fine but when my son rides it around the yard it's lacking acceleration and throttle response.The quad has new piston/rings,rollers and belt. Any suggestions?
Old Jul 10, 2011 | 09:47 PM
LT80's Avatar
LT80 Expert
Thank you.
Sounds like a plugged jet or plugged pipe.
Old Jul 10, 2011 | 09:52 PM
Will pull the carb tomorrow. Any chance the new belt could be bogging it down? The quad will continue to move forward when idling which it never did before.
Thank you for your assistance.
Old Jul 11, 2011 | 08:16 AM
LT80's Avatar
LT80 Expert
The belt won't cause a problem.
Did you service/check the clutchs while apart?
Old Jul 11, 2011 | 03:19 PM
No, just replaced the rollers due to flat spots.
Old Jul 11, 2011 | 03:33 PM
Old Jul 12, 2011 | 04:23 PM
LT80's Avatar
LT80 Expert
So what about that carb?
Maybe a gas cap vent plugged?
