KFX 80 rebuild
Old Jul 12, 2011 | 04:48 PM
centurion Power's Avatar
Cleaned the carb and adjusted the throttle for a slight improvement. Hole shot is non existent, mid range and top end is not where it should be. Engine sounds great under no load. Clutch cover is getting really hot and a couple of times I heard a noise possibly coming from the clutch area. Spring binding? Going to re-check everything this evening.
Old Jul 12, 2011 | 05:08 PM
LT80's Avatar
LT80 Expert
Ya, rear clutch is where your heading.
Could be a bad spring, sliding face binding, or my bet,,, the sheave face has broke off from where it slides.
You did put the big washer in place on the front clutch eh..
Old Jul 18, 2011 | 03:42 PM
Went back to the old belt and everything is working like it should. Low end acceleration is back so I guess I will leave it alone.
Old Jul 23, 2011 | 01:43 PM
Wishful thinking, the noise is back and upon further inspection one of the clutch pins on the sheave was in two pieces. Hopefully a new pin will eliminate the problem.
Old Jul 23, 2011 | 02:49 PM
  #15
LT80's Avatar
LT80 Expert
Pin?
Old Jul 23, 2011 | 05:42 PM
  #16
Pin?
The three pins between the sheave that the seat spring. One pin was cracked and in two pieces.
Old Jul 24, 2011 | 12:16 PM
  #17
LT80's Avatar
LT80 Expert
Wow..never heard of that happening before.
Old Jul 24, 2011 | 02:00 PM
  #18
Welcome to my world.
Old Jul 24, 2011 | 04:45 PM
  #19
LT80's Avatar
LT80 Expert
LOL. It seems to go around..
I pull up to the diesel pump and get excited cuz it's charging me $3.89 instead of $4.09.
I spend $200. to fill it up,then get home to see my fuel tank leaking..
Beeline08
Nov 11, 2016 04:00 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
CosmoM
Sep 21, 2015 04:57 PM
