No Spark on SunL HanmaR5
Old Jul 20, 2011 | 08:39 PM
Marmar1970's Avatar
Exclamation No Spark on SunL HanmaR5
I recently changed the alarm system control box on this machine. I also changed the head gasket. My daughter was able to ride it with no problem at all for 1hour after this was all done then they turned it off.
Now you turn the alarm on and it is a constant alarm like someone is trying to steal it and it has no spark again. It does crank over but again no spark. The only thing i haven't done is parked the dozer on it and pushed it into the ground cause that wouldn't make her happy.
Please help me with this issue.
Old Jul 20, 2011 | 11:55 PM
LynnEdwards's Avatar
Electrical Expert
So your alarm module is not working. The first thing to do is unplug it. The quad will still work (except all the remote functions of course), but the one additional difference is that you can no longer shut off the quad (if it should start up) with the ignition switch. You have to use the left handlebar kill switch. Else the quad functions the same.
So when you unplug the remote control/alarm module, then do you now have spark?
Old Jul 21, 2011 | 12:24 PM
Marmar1970's Avatar
No we tried that and still get no spark at all. Any other suggestions we can try will be greatly appreciated because our 6yr old is driving us insane as well as this problem.
Old Jul 23, 2011 | 03:58 PM
Electrical Expert
I've been traveling for a couple days. I had no internet access in either hotel room .
Here is the standard procedure for troubleshooting a 5 pin CDI ignition system (You'll need to find yourself a meter ). If by chance your CDI does not look the one below we will have to back up and do something different:
Is this a picture of your CDI?
Assuming the answer is yes, the first thing to do is eliminate all kill switches abd kill switch wiring:
Method 1) Unplug the CDI and remove the kill switch pin in the CDI connector on the wiring harness. The pin is held in with a spring tab on the pin itself. You'll have to probe into the connector and push this tab in order to extract the pin. Plug the CDI back in (kill switch wire dangling) and see if you have spark.
Method 2) Unplug the CDI. Turn on the ignition switch and set all kill switches to the run position. Use a meter to measure resistance in of the kill switch pin in the wiring harness connector to engine/frame ground. If the reistance is infinite on the 100K ohm scale then your kill switches/kill switch wiring are OK. If you measure zero ohms then you have a kill switch/wiring issue.
The other inputs your CDI needs to make spark are AC Ignition Power, and the Trigger signal. Do the following:
1) Unplug the CDI. In the wiring connector measure the resistance of the AC Ignition Power pin to the Ground pin. You should see 400 ohms or so. What do you measure?
2) Measure the resistance of the Timing/trigger pin to the ground pin. You should measure 150 ohms or so. What do you measure?
3) Leave the CDI unplugged. Set your meter to measure AC volts on the 100 volt scale. Measure the voltage on the AC Ignition Power pin to the ground pin while cranking the engine. You should see 40 to 80 volts AC while the engine is cranking. What do you measure?
4) Set your meter to measure AC volts on the lowest scale you have. Ideally this would be 2 volts but many meters don't go down this low. In that case use the lowest scale you have. Measure the voltage on the Timing Trigger pin to the Ground pin while cranking the engine. You should 0.2 t0 0.4 volts AC. What do you measure?
Now for measuring the output side of the CDI:
A) Leave the CDI unplugged. In the CDI wiring connector measure the resistance of the Ignition Coil pin to the ground pin. You should measure less than 1 ohm (but not zero ohms). What do you measure?
B) Plug the CDI back in. Set your meter to measure AC volts on the 20 volt scale. Set all kill switches to the run position. Crank the engine while measuring the voltage on the Igntition Coil pin to ground. Poke through the insulation of the wire if you can't probe the connector.
Caution: There should be moderately high voltage spikes on this wire. Make sure your fingers are not part of the circuitry. Don't touch the probe lead tips while doing this test.
What you should see is a lot of random numbers with lots of zero values as well. This is because the meter may catch all or part of the spark event voltage, with a lot of nothing in between. Describe what you see.
Note: Using a meter to measure this point produces highly variable results depending on the meter. What you really need is an oscilloscope, but most always a meter is all that is available. We have to do the best we can with what's available. Describe the meter results as accurately as you can - there is information there to chew on....
pgamboa
Dec 24, 2023 11:52 AM
fordfaithful21
Dec 7, 2015 05:52 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
