2008 sportsman won't key start
Old Jul 26, 2011 | 02:44 PM
wroberts's Avatar
Default 2008 sportsman won't key start
purchased a used 2008 sportsman 500 with 70 miles, have put 70 miles since purchase 3 wks ago from dealer. used on farm every day. now won't start with key, can jump start across relay and can use pull start. checked fuses, ok, pulled leads and checked relay, ok. all functions in spedo work. battery shows 12.75 volts. can't get the ecu to go into diagnostic mode as manual says in P and turn key on then off three times in 5 sec to see if any fault codes. anyone have any ideas
Old Jul 26, 2011 | 03:24 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
welcome to the forum. are you refring to the solenoid that your jumping across(2 big cables) to start the bike? if so then the solenoid is what is bad. when you turn the key to the start position it should send power down to the solenoid via. the small wire connected to the side of it. i can't remember on my 800 if it had to be in park or neutral and then turn the key on and off 3 times w/ in the 5 seconds.
Old Jul 26, 2011 | 03:47 PM
Spdecat's Avatar
Where are the fuses on your 08 ? I have a 08 and in the 3.5 years I'v had it I'v never came across a fuse .
Old Jul 26, 2011 | 04:23 PM
wroberts's Avatar
I unhooked the lead wires and jumped the solenoid with 12 v and worked fine. no elect from switch.
Old Jul 26, 2011 | 04:26 PM
wroberts's Avatar
fuses are inside the front cover under rubber cover with the spare fuses on top
Old Jul 26, 2011 | 06:06 PM
Spdecat's Avatar
Your's must be EFI then as my 08 have none .
whitty
67
Feb 24, 2021 02:52 PM
neilbedwell
Nov 10, 2018 11:02 AM
RedRancher
Jun 4, 2015 12:29 PM
Schneider
Jun 4, 2015 11:37 AM
1000gade
May 27, 2015 12:37 PM
