trx 400ex tires
Old Jul 26, 2011 | 03:41 PM
quadtrx400ex's Avatar
Question trx 400ex tires
i want to get itp hole shot tires but when i size them (rocky mountain) the only size is 20x11-9 and mine are 20x10-9?!?! although it says the will fit the Honda TRX 400ex (2004) my manual says otherwise will they fit?
Old Jul 26, 2011 | 07:12 PM
m.jones101604's Avatar
you should be fine I went up 1" width on my 450 just a little better traction
Old Jul 28, 2011 | 08:18 AM
Default tires
will they fit my rims though? there the stock rims on an 04 400 ex?
thanks for the help
Old Jul 28, 2011 | 09:10 AM
budedm's Avatar
The width is the 10/11 number so you can vary that an inch either way. Your rim is 10" wide. So, the 20 x 11 - 9 tire will be 1/2" wider on each side of the rim. No problem. But the DIAMETER of your rim is 9". You have to stick with a 9" diameter tire to fit your rim. The first number in the 20 x 11 - 9 is the total outside diameter (or height from the ground to the top of the tire). This may vary. The second number is the width. This may vary. The third number is the diameter of the rim itself. The tire you put on a 9" rim MUST be 9".
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
XxS0ccerstarxX
Sep 8, 2015 06:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
