polaris 500 wont start clicks until battery is unhooked
Old Aug 20, 2011 | 06:53 PM
daytonrocketry's Avatar
Default polaris 500 wont start clicks until battery is unhooked
i was riding today nothing extreme, no water, mud or jumping just cruising with my son. when all of a sudden it died and wouldnt start. their is a plastic bag for lack of better desription. it click out of it i have a spair cdi, relay and changed them out i dont know what the little bag with three wires coming out of is. plz help
Old Aug 20, 2011 | 07:53 PM
Welcome to the forum! This is the main fuse(circuit breaker) if its up by the battery. Its designed to switch off if there is a short or overload,plus can corrode even in the sealed pouch and short out.Depending on the model,there is another one or two under the front panel that are 10 amp fuses. You can slit the pouch and check that both terminal nuts are tight and the little square fuse isn't corroded. Just replace if it is and you can usually find these at most auto stores. It should have 20 marked on it for 20 amp rating on the one by the battery. OPT
Old Aug 20, 2011 | 08:28 PM
you said there might be a short? it clicks every few seconds and the bag was a little hot even after the drive home. ill try the open and change the fuse tomorrow and post if it fixes it. ty for the quick reply
Old Aug 20, 2011 | 09:35 PM
ok i changed it made no difference. the new one cut off an old harness. if its a short do i need to change the whole harness? what can make that switch keep clicking?! i hope its just a short
Old Aug 21, 2011 | 12:35 AM
If you used an old circuit breaker you could have the same problem,either that or you have a short in the harness wiring that keeps tripping the breaker. You can always hook up up a plain inline 20 amp automotive fuse and see if it blows the fuse. If it does,then you will have to trace the wiring to find out what the problem is,either a direct short or bad ground,etc. OPT
Old Aug 22, 2011 | 08:39 PM
ty for all the info. I gave up and it went to the local mechanic today. ill post what was wrong when i get it back.
Old Sep 22, 2023 | 03:50 PM
Cody22's Avatar
Default I have the same problem....
I was hoping you could tell me what they figured out with your four wheeler because mine is doing the same thing? If I hook up the battery the circuit breaker underneath the seat keeps clicking. I was simply riding and hit a little bump and the four wheeler cut off.
tiresharkdbb
Sep 3, 2017 02:06 AM
jayking232003
Jun 9, 2015 02:54 PM
vipers
1) Engine problems..
May 31, 2015 09:12 AM
bbehrendt
May 28, 2015 09:25 AM
1000gade
May 27, 2015 12:37 PM
