Winch Wiring
Old Aug 20, 2011 | 06:56 PM
highwayman's Avatar
Default Winch Wiring
Hi I just bought a Superwinch 3000 kit for my new 500 Foreman. It looks real easy to install except for the red wire coming from the switch which goes to the ignition. Could I hook this to the solenoid and have it work live without the ignition on? Or not hook it up at all?
Bob
Old Aug 21, 2011 | 12:45 PM
ddrumman2004's Avatar
I am assuming that this red wire is from the switch that controls in and out movements of the winch.
If so, you can hook it up to the starter solenoid on the battery side and get power to run the winch with the key off.
This wire controls voltage to the winch solenoid thru the switch. Without it connected, the winch won't work.
Old Aug 26, 2011 | 04:15 PM
JeffinTD's Avatar
Personally I prefer to wire that to keyed power for safety.
IMHO it is better to tap the + side if the accessory socket as it is fused, and not critical to the machine running.
Old Aug 30, 2011 | 12:32 PM
R Walter's Avatar
I would also recommend only wiring it to keyed power. I had to change the wiring on my winch on a 97 Honda Foreman 400 from the solenoid to a keyed power on-only wire because it would only come on intermittently.
Old Aug 30, 2011 | 04:18 PM
highwayman's Avatar
I think I will tap into the acc plug
toonces
Oct 19, 2015 02:21 AM
MNatv89
Aug 10, 2015 02:20 PM
Bratman2
Jul 23, 2015 12:36 PM
toonces
Jul 11, 2015 12:01 PM
cornermike
Jul 8, 2015 11:44 PM
