2009 Sportsman 500 EFI misses in midrange
Old Aug 28, 2011 | 10:48 PM
gbikerman9867's Avatar
Question 2009 Sportsman 500 EFI misses in midrange
Hey guys! I'm new to the forum and looking for a little sage advice. I have a 2009 Sportsman 500 HO EFI and it started running terribly on my last ride. It starts right up and idles all right 1150-1200 rpm, but once you give it throttle it misses (sounds like it only fires every other stroke) until you give if full throttle and then it runs ok. It also backfires under compression going down hill. The check engine light comes on intermittently. I have tried going into diagnostic mode to get a code (Turn ingition to on position and then turn off and on three times in less than 5 seconds) and it will not go into diagnostic mode. I have a K&N air cleaner and it is always cleaned. I changed the NGK plug (old one looked good, no fouling). I looked for wiring problems with the EFI and saw that the yellow wire coming from sensor (not sure which one, three wires mounted on top of air intake) had the casing worn off but the wires looked intact. Any help I could get on this would be greatly appreciated.
Old Aug 29, 2011 | 12:10 AM
RickCJ7's Avatar
Thats the t-bAP sensor and the wiring inside is most likely broke, they make a repair kit for the problem.
Old Aug 29, 2011 | 12:32 AM
#2876315 map sensor repair kit as mentioned,plus make sure the rubber grommet isn't split,had several that would split because of the vibration. OPT
Old Aug 29, 2011 | 10:02 PM
Back on the trail thanks to RickCJ7 and Old Polaris Tech. Tested the T-BAP harness and the orange and purple wires came right out. Decided against buying the OEM harness scince it is the same gauge wiring as the stuff that broke. Made pigtails using 16 GA.22 strand connected diretly to the sensor.I filled the sensor (connector cavity only) with RTV blue silicone (sensor compatable) for vibration dampening and weather proofing. I then slipped the whole harness assembly through a section of old bicycle inner tube and secured with a zip tie to eliminate any future chaffing. My ride once again is happy!! Thanks for the help guys.
Jmuddin284
Jan 19, 2026 07:16 AM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
Big bousse
Sep 26, 2015 10:42 AM
Sportsman850
Jul 31, 2015 04:25 PM
