2001 starter jet size???
Old Mar 14, 2001 | 06:05 PM
DS650DAVE's Avatar
I read in "ATV Sport" that the 2001 Ds has a new "starter jet".Could someone tell me what size it is? Thought I might TRY it in my 2000 DS,does help, has anyone done this ?Did it help off idle response ?
Old Mar 14, 2001 | 06:08 PM
ScoobyDFW's Avatar
the 2001 starter jet is a #45. the dynojet kit, a larger pilot jet, and the 2001 carb spring help throttle response.
Old Mar 14, 2001 | 07:02 PM
DS650DAVE's Avatar
Thanks Scooby, I have the 2001 updates,dyna jet kit already .Still seems to have a slight hesitation,do you think this will make it go away if I replace the "starter jet" with the 2001 size?
Old Mar 14, 2001 | 09:32 PM
ScoobyDFW's Avatar
I don't know if the starter jet will help. The pilot jet and pilot fuel screw is where I would start. You should check to see where the pilot fuel screw is set. It may be set too lean. Try turning the screw a couple of turns out/richer and see if it helps. If so you may be better off with a larger pilot jet. Stock is #40.
What pipe and airbox setup are you running?
ghost civic
Jan 15, 2020 07:43 AM
raceware
Jul 30, 2015 06:59 AM
ghost civic
Jul 19, 2015 10:13 AM
ghost civic
Jul 15, 2015 10:48 PM
maxjung
Jul 14, 2015 03:10 AM
