02 400ex rear axle knocking
Old Sep 3, 2011 | 04:20 PM
football4life's Avatar
Default 02 400ex rear axle knocking
Hey guys, I have a problem here, bear with me,
Yesterday I was riding when I started hearing a knocking/clunking sound coming from the rear. Took the bike back to the garage and noticed the right rear hub had came loose. tightened it back up. when i took it out again it is still knocking when i make a right turn. If i make a left, no knock. If i put all my weight on the right and turn right, no knock?
Now i have noticed the rear axle has play up and down/front to back when it is jacked up but no side to side. also, the chain when rotating gets tight and then loose.
Anyone have any ideas here?
Thanks everyone
Old Sep 3, 2011 | 04:30 PM
88moto4's Avatar
your rear bearings are bad
Old Sep 3, 2011 | 05:08 PM
95wolv's Avatar
I agree, also, the crush tube between the bearings may also be worn/rusty/damaged, so take it all apart and get a complete rebuild kit. Or, if you have some spare cash laying around, nows a good time for a tapered roller carrier replacement, 4 times as strong and probably the last set of bearings you will need.
Old Sep 3, 2011 | 11:35 PM
Thanks guys I had a hunch it was that but wanted to double check before I started . Anybody have good luck with online places to buy a rebuild kit?
Thanks again
Old Sep 6, 2011 | 07:51 PM
Has anyone made a writeup on how to change the rear axle bearing? Also, I am going with all *****, are they a reliable brand?
Old Sep 6, 2011 | 08:53 PM
mudslinger2's Avatar
I haven't been stuck since the last time!
Default All *****
Only experience I have had with All ***** was with wheel bearings...they are great if you like tearing it apart and putting it back together often! Had front wheel bearings from all ***** that lasted 100 miles! They are cheap if that is all you are looking for!
Old Sep 6, 2011 | 11:29 PM
so maybe i should go with piviot works? any other inputs. Also, what aftermarket carriers are recommended
1986Vmax540
Jul 9, 2021 09:53 PM
STLyamwar
Jul 25, 2020 04:44 AM
bigred20653
Aug 31, 2015 12:41 PM
DeFox500
Aug 14, 2015 05:59 PM
Rider252
Jul 6, 2015 03:37 PM
